What tables in hp tuners are changed for 42lb ford green tops?
Old 08-26-2009, 05:34 PM
slammin86's Avatar
Default What tables in hp tuners are changed for 42lb ford green tops?
I know that the "Injector Flow Rate vs KPA VAC" table is changed.
"48.48824 48.79827 49.10830 49.41832 49.66635 49.97637 50.28640 50.59643 50.84445 51.15448 51.46450 51.71253 52.02255 52.27057 52.58060 52.82862 53.13865"
These are the values that are in mine, and I believe them to be correct.
My question is what other tables are you changing?
Are you changing the "Offset vs Volts vs VAC", the "Min Injector Pulst", the "Default Injector Pulse", ect?
If so, could someone share these values with me?
Old 08-27-2009, 10:56 AM
5_02ls1's Avatar
when i done my svo 30s all i changed was the ifr tables....car runs fine...
Old 08-27-2009, 01:18 PM
JonCR96Z's Avatar
If you don't have the correct data then you shouldn't mess with the other tables. The IFR will get you by for now, but the IFR @ 0 kPa should be ~52lbs/hr on the green tops.
42lbs/hr is rated on 39psi, that's around 45lbs/hr @ 3bar.
You'd be surprised how many people have completely wrong values for IFR.
Quick Reply: What tables in hp tuners are changed for 42lb ford green tops?
