Please help with spark knock problem...
Old Jan 12, 2004 | 12:04 PM
joecar's Avatar
Okay, I did the following...
1. Replumbed the PCV for reverse flow out thru the oil filler cap (and the PCV valve is now vertical); seems to work reasonably well, although I did detect some oil in the PCV valve (small amount); I'm waiting to get my photos processed onto CD; I post them as soon as I can (no digital camera yet); I'm now going to make a "rev 2" cap with a smaller hole and some kind of filtering material/mesh; keep you posted;
2. Applied top engine cleaner (...you should've seen the BIG smoke...!!!!); this has eliminated almost all the ping;
Thanks for all your help.
Old Jan 12, 2004 | 12:29 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
7 degrees of knock is a lot, and audible knock is rare and BAD.
I would look at your fuel system, maybe you have a bad or clogged injector.
If you are still in warranty, why not have them go thru this stuff.
Your PCV mods are not needed for a stock car you have other problems don't bandaid it IMO.
Old Jan 13, 2004 | 11:34 AM
joecar's Avatar
The dealer did not want to do anything, and said to use higher octane (which I already was) and to use octane boost for one tankful; injectors seem good (I did the injector balance test using EFILive V6 - the rpm drops were all very close to each other);
With the stock PCV arrangement, it does suck oil, as many people can verify; why does the LS6 use a different PCV arrangement...?
Old Jan 13, 2004 | 06:13 PM
WS6FirebirdTA00's Avatar
cause the ls6 is a better motor and they fixed the ls6 **** ups i guess. mine will take in quite a bit of oil, my catch can and filter set up get really nasty
