lt1 tunercats
Old Sep 5, 2009 | 10:47 PM
97badass's Avatar
Default lt1 tunercats
when trying to get the tunercats to tune my car do i get the tuner? or the rt tuner? the car is obd1 since it is a 95. or is there a different tunercats that i need instead?
Old Sep 5, 2009 | 11:35 PM
poconojoe's Avatar
It depends on what you want to do and if your ECM uses an EPROM or a flash memory, RT time will allow you to tune in real time, but requires special hardware, if your ECM uses EPROM's. I got mine from Craig at moates.net
Old Sep 5, 2009 | 11:40 PM
roughneck427's Avatar
cant use the RT version on that year
Old Sep 6, 2009 | 06:29 AM
edcmat-l1's Avatar
Yep...
Old Sep 6, 2009 | 03:02 PM
97badass's Avatar
Originally Posted by edcmat-l1
Yep...
ok so just the regular tuner? download it to my laptop hook the laptop to the diagnostic port and i can check everything and change what needs to be changed? i watched the guy when he tried to tune my car yesterday but he went so fast idk what all he done. he showed me a table that had blue dots EVERYWHERE with an average line in the middle. and by those dots being everywhere he said i had bad plug wires which i did i found 2 cut wires. so i need to go in and fix what he missed. i cant afford to pay 125 every time i need my computer tuned.
Old Sep 6, 2009 | 04:12 PM
you will need the ee def file its like 20 bucks also
Old Sep 6, 2009 | 06:55 PM
edcmat-l1's Avatar
You'll need the software, the definition file, and the cable. There's a link on the TC website for the place to get the cable.
Old Sep 6, 2009 | 08:52 PM
Theres a place called www.mastach.com they have the cable for like 40 bucks it doesnt have the blow molded connector but has pins so you can use it either on obd1 connectors or the odb 1.5 like your 95 you have there ive used it for about 4 years and had no problems with it
