Need help, just got my Turbo SS running.
Well, to make a long story short I had my tuner do a basic speed density tune so I could get my SS running to check for leaks/etc before I sent it to him to have dyno tuned.
Anyways, here's the problem I am having and am hoping someone can help shed some light on ideas and things to check.
When starting dead cold, it idles great but very rich (heavy rich exhaust smell with smoke) for about 2-3 minutes then stumbles and dies. Will not re-start, have to pull the fuel pump fuse to get it started. Funny think is after I pull the fuse it idles for a few minutes before it dies. I would't think the amount of fuel in the lines would keep it running that long.
Also, I forgot to mention, when it does start when it's cold when you touch the throttle pedal it stumbles and dies.
Here's the list of stuff I am working with.
2005 317 Head Longblock
LS6 Intake
Comp 918's
Comp Cam (small specs, .560 115)
MPT76mm Turbo - front mount
60lb Mototron Injectors
Thats the basics. Question, I have not installed my racetronics fuel pump kit due to making sure it started and ran before did much more. Would that be causing the problem?
Also, I noticed on my boost gauge it reads zero vacuum, is that normal for a FI vehicle? Thanks
LS6 Intake
Comp 918's
sounds like you're fuel pressure at the rail is too low, since you have NOT installed the newer fuel pump kit.
Your injectors are trying to compensate for the lower pressure, and it's flooding your engine. It's dumping so much fuel in that you're "flooding" the engine . . . hence you're staying that it still runs with the fuel pump relay disconnected.
There's a table in your tune that references the fuel rail pressure, and the injector flow rates . . . and that's called "injector scaling"
Get the new fuel sys installed or have the tune redone for the pump that you're using
But anyways, I installed the new pump last night and will finsih the wiring tonight and crank it up. I'll let you know, thanks.
Be sure you change the oil and check the plugs before you start the engine again. If you did indeed have cylinder wash after sitting all night bearings may start up dry and gas washed and may spin or score, Plug may be fouled from dumping gas. also spin it over with no hot to coil until you see the oil gauge move to be sure you have fresh oil to the bearings that may now be dry from gas in your oil.
