Help With SES Light (Code P0121)
Old Sep 6, 2019 | 10:44 AM
Blownbayou's Avatar
Well the light came back a few months ago (rarely drive the car)..... Traction control light as well. Turn off AC and run it and the traction control light goes back to normal.... Hope to see something else on this
Old Sep 6, 2019 | 03:36 PM
Russ K's Avatar
The P0121 code is caused by the lower low RPM vacuum when performance camshaft is installed. You need to disable the P0121 Error Max & Min Map test. Do this by setting the max to 100 KPA & the min to 0 KPA.
Russ Kemp
Old Sep 7, 2019 | 10:45 AM
Linson's Avatar
Russ Kemp
I have the same issue. This tracks with me because I have a performance cam and A/C deleted.
