engine temp to go into closed loop?
Old Nov 30, 2003 | 08:19 AM
WS6FirebirdTA00's Avatar
Default engine temp to go into closed loop?
how hot does the engine need to be to go into closed loop?
Old Nov 30, 2003 | 12:38 PM
wrencher's Avatar
wrencher
There are alot of variables that go into the equation.
The CTS/IAT at start up ,time & O2 heater & feedback.
Old Nov 30, 2003 | 12:39 PM
well im just wondering if after i have been driving my car for about 10-15 min and my temps are up to 170-175 and the fans are cycling on and off if i can monitor my data correctly
Old Nov 30, 2003 | 12:52 PM
wrencher's Avatar
wrencher
By then it has been in closed loop for a while.
Look thru do you have a perameter/PID that says loop status?
Old Nov 30, 2003 | 04:27 PM
loops status? i dont think i do..
Old Nov 30, 2003 | 05:44 PM
jimmyblue's Avatar
Moderator
Just watch for when the fuel trims start to be something
other than zeros, and note the coolant temp....
Old Nov 30, 2003 | 06:53 PM
ooook got ya, my air/fuel takes a while to bounce around when its cold. when its cold it stays in one spot then after about 4 miles it moves, once it starts to move am i in closed loop most likely?
