BLM question Park vs. Drive
But to answer your question, I would guess that one clogged injector would do this. The clogged injector can squirt enough fuel at idle, but not enough at higher RPM. Run some fuel injector cleaner thru your gas and so if anything changes for you.
C-Rules: What are the IAC counts and commanded idle speed both in park and in gear? I've seen cases where adjusting the throttle stop and changing the IAC counts can skew BLMs one way or the other. Also, what throttle body?
another question i have is what could cause a car to have split blms in SD mode but not when running a MAF?
