Help-fuel pressure problem
The issue is now, it is VERY hard to start, which has never been a problem before the tune. It will turn over for 4-5 secs. before it fire up.
The issue appears to be fuel related. When I switch the car on, it has no fuel pressure. Also, when I switch the car off, the pressure quickly drops from 59 to o in just a couple of seconds.
Is there somthing that was changed in the tune that is creating the fuel pressure problems?
Thanks for any help
I installed a Z06 MAf before the tune, which made it a littler harder to tune, and he just said that it now took a "little longer to crank"
"With FP dropping that fast after the pump is turned off
I'd bet you have a leak in the fuel tank.
I had the fuel line in the tank come loose from the fuel pump."
If a line had come loose, wouldn't it affect the pressure/operation at all times? The pressure stays at a perfect 59-60 during all other operation except WOT, where it did actually drop a little lower than I had hoped while we were dyno tuning.
You might have a bad FP regulator, that is in the tank.
FP should not bleed off that fast after the fuel pump shuts off.
It's not uncommon for FP and battery voltage to drop a little at high RPM.
The fuel pressure used to drop only 2-5 psi after I shut the car off.
NOTE: I pulled the injectors and laid them on the engine (on a towel) and switched the car on, and there was NO leak anywhere.
have little to no FP if it was stuck open.
Fuel is returning to the tank somehow.
Why would there be a leak with the fuel rail off?
Also, I read that one characteristic of a bad regulator was it leaking fuel. Wasn't really sure how to check for a bad regualtor
