Tps,map sensor
Old Oct 4, 2009 | 04:19 PM
chase3's Avatar
Default Tps,map sensor
ok, if i turn on the a/c i throw the tps code in no time. i bought a scan tool and it actually says tps code even before the ses light comes on. so i took it to my tuner and he said yeah your tps and map have low readings, but he didnt do anything. i have already replaced the tps sensor once and it still does it, and the map one showed up also with the a/c the other day. i have no idea where to even start. the tps code will also come on without a/c everynow and then after letting it come down from like 5500 rpms..ANY IDEAS??? Thanks Chase
Old Oct 4, 2009 | 06:23 PM
jimmyblue's Avatar
Moderator
Start by measuring the TPS voltage (not %) and
go from there. Too low at idle or too high at WOT
both will set codes.
Old Oct 5, 2009 | 10:02 AM
chase3's Avatar
tuner told me that the voltage is low on the top end..which is why i think it has lean spots when i drive over 2500rpm
Old Oct 5, 2009 | 01:09 PM
jimmyblue's Avatar
Moderator
That doesn't seem too likely a scenario to me. TPS
doesn't have much to do with top end fueling other
than the decision to enter PE (all or nothing, no
"spots"). And I wouldn't take anybody's word like
that, just got to measure / read the scan tool volts
value.
