Reset the Air bag light?
Old Dec 5, 2003 | 12:53 PM
Craig98Z28's Avatar
Default Reset the Air bag light?
Can it be done? It came on when we did my header install. Apparently you're not supposed to turn the steering wheel with the steering column disconnected. Of course, this is written on the steering column that was removed
Anyone had this?
Old Dec 5, 2003 | 01:34 PM
WS6FirebirdTA00's Avatar
its all hooked up right nwo right? try to reset the computer with a predotor or try to disconnect the battery, thats my guess...
Old Dec 5, 2003 | 08:44 PM
wrencher's Avatar
wrencher
You prolly un-centered the clock spring.
Then when driving the car normally afterwords the clockspring broke.
It is a harness inside a disc that allow wires to go to air bag steering wheel controlls (if equipt) etc.
Does the horn work?
Old Dec 5, 2003 | 11:02 PM
snketr's Avatar
I did this in my Vette, Snapped the ribbon in the SIR coil. You have to put a new one in it's like $100
Old Dec 10, 2003 | 09:37 AM
Craig98Z28's Avatar
Yes, the horn still works.
So, since that lights on does that mean that if I get in an accident the airbag won't deploy?
I was kinda hoping it wasn't going to be the $100 fix
