Deleting TM issues.....
Old Dec 7, 2003 | 02:49 PM
1ORANGEWS6's Avatar
Default Deleting TM issues.....
Has anybody had any negative effects from doing this? I deleted mine and I've heard mixed results from several people from doing this.
Old Dec 7, 2003 | 03:10 PM
HumpinSS's Avatar
Yes the only negative effects i have is when I poweshift from 1st to 2nd and my neck snaps
Old Dec 7, 2003 | 08:16 PM
1ORANGEWS6's Avatar
How long have you been running without TM? I just leave mine in drive.
Old Dec 8, 2003 | 12:02 AM
Cal's Avatar
Cal
A negative effect might be blowing out your 10 bolt stock rear . . .
Old Dec 8, 2003 | 12:06 AM
CAT3's Avatar
Restricted User
I am going to go ahead blame last nights 3-4 clutch pack blowing out in my 4L60E on deleting TM. Yep sounds good. I really dont think spraying 150/175/200 shots of nitrous thru the shifts has anything to do with it
No reportable negative effects.
Old Dec 11, 2003 | 12:50 PM
LT99LS1's Avatar
One of the negative effects is it spins the tires going in to 2nd gear.
Old Dec 11, 2003 | 03:23 PM
goodhands's Avatar
I can not seem to keep the tires from smoking up through first gear. That rev limiter comes up so fast. second is not so bad though maybe 30 feet of rubber.
Old Dec 11, 2003 | 04:52 PM
Nickn20's Avatar
if you have a stock tranny, premature failure may occur.
