code po106
Old Oct 25, 2009 | 06:25 PM
02b4ccamaro's Avatar
Default code po106
my friend at work was messing with my tune using hpturner, now the car my car will not idle and is shooting a po106(map sensor code) so the question is if i had a bad map sensor would it cause the car not to idle.
Old Oct 26, 2009 | 02:39 AM
35th SS's Avatar
I believe its due to low vacuum.raise your idle a bit.
Old Oct 26, 2009 | 08:46 AM
that make sense because when the car trys to run it only idles at 500-600 rpm
i just what to know if the would run w/a bad map sensor.
Old Oct 26, 2009 | 11:37 AM
GMCHammer's Avatar
Not on its own. Hook his HP Tuners up to it and use the scan tool to see if the MAP sensor is reading when you give it throttle.
