AEM WB readout in HPT
Old Oct 27, 2009 | 05:16 PM
Mark98SS's Avatar
Default AEM WB readout in HPT
The readout for my AEM WB has always been a kind of jagged line. I imported a log into Excel & smoothed the raw data with a 10per moving average:
This is 3rd gear from a 10.23/130mph pass. Should I worry about the spikes & dips or should I go with my instinct that it's basically fat?
Old Oct 29, 2009 | 05:48 PM
carlrx7's Avatar
hey,, i have the aem uego too, and mine is the same, not smooth, i dont know why, probley something to do with how fast the wb is spitting singnals to the EIO. how do you do the 'smoothing' in excel?
-carl
Old Oct 30, 2009 | 06:53 AM
Mark98SS's Avatar
I glad I'm not the only one experiencing this. To smooth the line you need to export the log to Excel, you'll get everything. Delete all the columns except RPM & WB. Highlight the WB column, "Insert" a chart, choose 2D line chart. Once you have that, right click on the jagged line in your chart & you will have the option "add a trendline". I use the moving average, you can select how many periods (data points) to average, the more you use the smoother the line. 6-10 seems to give a fairly realistic picture.
Old Oct 30, 2009 | 07:02 AM
Frost's Avatar
I wouldn't tune a car by that...
Old Oct 30, 2009 | 08:49 AM
AFASTYZFR1's Avatar
+1
I just got a AEM wideband and it seems accurate compared to a LM1, but its just too jumpy. Works well as a warning gauge though.
Old Oct 31, 2009 | 12:44 AM
Mark98SS's Avatar
Originally Posted by AFASTYZFR1
+1
AEM & HPT logs got me thru 250 passes at 7psi on the original LS1 motor, I suspect the nice smooth readouts you see from a Dynojet or Mustang are automatically averaged.
