Did the blackbox to 411 swap .. problems
I used a 411 PCM and flashed a stock savana van file onto it.
We started it up and it will not idle , runs very rish at the somewhat of an idle is have (runs very rough until about 1500-2000RPM).
It does throw code P0200 (Injector Malfuntion)
Anyone know where to start with this ?
Anyway of telling of wehat injector ?
Its an 97 Chevy truck with a 5.7L that I swapped a 411 PCM flashed with a Savana van 5.7L file.
It runs like crap at idle, smoothes out after 1500RPM. and throws a P0200 code.
I checked the pins to ensure they were in fully, which they are. Doulbe checkeed the PCM grounds and they are also pinned properly.
Jeff
If you don't want to just put a meter across them one
by one and look for discrepancies in the average (DC
reading) coil voltages.
