Need a dyno tune in Pittsburgh
Old Nov 24, 2009 | 05:27 PM
isspeed's Avatar
Default Need a dyno tune in Pittsburgh
I am in the process of installing TSP 5.3 heads, tourqer V3 cam and all the bolt ons and i'm looking for a good tuner near Pittsburgh. I live in Indiana PA and I'd rather not drive any further than an hour away. Or do you think a mail order tune would be good enough? Any info would be much appreciated!
Old Nov 24, 2009 | 05:33 PM
isspeed's Avatar
Not sure that it matters but I forgot to mention that my car is a 2001 LS1 Camaro M6
Old Nov 24, 2009 | 08:26 PM
edcmat-l1's Avatar
That's too bad, I was just there.
Old Nov 25, 2009 | 03:40 PM
isspeed's Avatar
That sucks! Any chance you'll be back soon? ALso i have a question you may be able to answer. I plan on towing my car to wherever i get the tune done but i would like to start it up and make sure there are no leaks or complications before i take it anywhere. Is it safe to run it for a while at idle without a tune. I was told i could if i left the stock injectors in. Thanks!
Old Nov 25, 2009 | 03:49 PM
edcmat-l1's Avatar
I won't be back until the spring. The guys that set this trip up are planning to get a group together in the spring.
If you're going to start it, do it on the stock injectors for sure.
Old Nov 26, 2009 | 07:58 AM
wkdivr's Avatar
Search for PCMforless.com. I think he's located in Indiana, PA.
Old Nov 30, 2009 | 08:45 AM
isspeed's Avatar
Thanks for the suggestion! I guess pcmforless moved to Ohio but they still have a Dyno they use in Sarver PA which is closer than Pitt for me so that will work out good!
Old Jan 2, 2010 | 12:03 AM
75novacaine's Avatar
so did you get your car tuned yet? how did it turn out and who did you end up using and how much did it cost? im in kittanning and curious.
Old Jan 5, 2010 | 03:01 PM
USRobo's Avatar
You can try this place
ASAP - Auto Service & Performance by Ed - Home of ASAP Mustang Dyno
4768 William Flynn Highway
Allison Park, PA
(412) 492-7454
This is on Rt 8 near the PA Turnpike. Check his price for tuning on the Dyno. I think he uses HP Tuners.
If you find a good tuner in the Pittsburgh area let me know. I want to have my vette dyno tuned again.
