Identifying year of PCM and Harness
Old Nov 24, 2009 | 10:08 PM
jonathan_ed3's Avatar
Default Identifying year of PCM and Harness
I'm wondering if you guys can help me identify the year/make/model of my PCM (if it's possible?).
The number on the PCM is 16238212.
Is there anyway to validate this came from a '98 LS1 M6 equipped car? Does it matter if this PCM was originally auto or M6?
Also, how do I identify if my engine harness is for a '98? The only thing I can see on it is the section that comes into the cabin. It's got a bar code and a sticker with #207561 and it has 3 plugs.
The other harnesses I have seen pictures of, the interior cabin section only has 2 plugs.
Any help will be appreciated!!!
Old Nov 24, 2009 | 10:12 PM
Frost's Avatar
that's a 98 PCM; 16238212
Old Nov 24, 2009 | 10:23 PM
eseibel67's Avatar
Yes, its a 98.
The hardware is the same for manual or auto, however it can easily be reflashed for either if it's the wrong version for your application.
Old Nov 24, 2009 | 10:30 PM
Okay, awesome. Thanks for the reply guys.
Any info or advice on identifying what year my engine harness is?
Old Nov 24, 2009 | 10:47 PM
eseibel67's Avatar
This might sound a little crazy, but I believe the 1998 harness uses a 3 pin connector for the coolant temp sensor, and 99-02 uses a 2 pin.
Old Nov 25, 2009 | 07:32 AM
Frost's Avatar
You are right!
