98 pcm
Old Nov 26, 2009 | 05:41 PM
Mustang Hat'r 2's Avatar
Default 98 pcm
What type of extra things will I have to deal with tuning a 98 car?
Putting LS7 in it any different than a 99-02?
I know its off based but what else is different, wire harness, PCM, Gas tank, heads and valve covers. Anything else I should know.
Im looking for a new TA and the 98 are all over. What about PCM and wire harness conversion?
Old Nov 27, 2009 | 11:03 PM
I searched and found that the 98 PCM is usiable, but tuning is limited.
It will be a 418 with a LQ9 heads, fast 102/102 and 1-300 shot of spray, with no MAF.
Will the 98 work?
If I switch can I get my 02 wire harness modified to work with the internal dash of a 98 that seems to be the big issue?
Old Nov 28, 2009 | 06:39 AM
psiconversion's Avatar
LS1Tech Sponsor
Go aftermarket on the wiring harness and use a reprogrammed factory PCM.
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Nov 28, 2009 | 01:59 PM
Who makes it? Price?
Just need the dash etc to work the hole drivetrain will be replaced.
Old Nov 28, 2009 | 02:45 PM
1fast bird's Avatar
Unless you plan to boost the motor, a '98 ecu should work. The only difference in ls1 motors and ls2-ls7's are the location of the knock and cam sensors. Oh and make sure the ls7 has a 24 tooth reluctor wheel on the crank. Newer lsx motors have a 58 tooth wheel that no f body ecu can read.
If you want alot of tunability, run a Big stuff 3. The money saved on a '98 over a '99 or newer might buy you a good standalone like that...
Old Nov 28, 2009 | 08:57 PM
its over 2k. Little out of my league. Might take a trip to the local tuner and ask them if they can handle the 98's. Im 15 mins from new era
Old Nov 28, 2009 | 09:54 PM
rpmauto's Avatar
The 98 pcm is fine, just a few quirks. Backup ve table and such. You can repin the harness to work with a newer ecm, but you have to have efi-live to make the fuel gauge work. I dont believe that hp tuners will do that.
Old Nov 29, 2009 | 06:39 AM
LS1Tech Sponsor
There are ones on ebay for $450 that look nice. Appears they come with connections for speedo and tach.
__________________
Ebay Store
