CONFUSED and LOST!!! please help, no start or gauges
looks like you may have found the problem, weak terminal tension or dirty contacts in your fuse box. try pulling all your fuses in and out to clean them if that does not work have your buddy watch the cluster with the ign on and try wiggling all the fuses until it comes on. if one of these methods fixs it i like to use terminal cleaner from radio shack or use a small pick to increase terminal tension. oh ya if you power on the two fuses i mentioned above you should have constant pwr at one of the pins in the fuel pump relay.
good luck!
good luck!
went to roll the key forward, and heard the fuel pump prime! so one of the above was out of whack, but guys i really dont think it was the grounds.
BUT NOW MY ODO DOES NOT TURN ON AGAIN!!!! car starts and idles fine (for a MS3 untuned) but no odo on. Any ideas on this one now??
Its going to performance by joe in st. louis to get tuned x-mas eve morning, i need to have this thing perfect, and ready to dyno
