LS1edit or dyno tuning ....
Old Dec 15, 2003 | 02:14 PM
30th t/a's Avatar
Default LS1edit or dyno tuning ....
im going to be geting alot of bolt on's, ls6 intake and a cam this spring. should get the ls1 edit or just get it dyno tuned. next summer im going to get heads.
pay $550 for ls1 edit, $300+ for the laptop or $500 for the dyno tune?
are these prices right also?
Old Dec 15, 2003 | 08:27 PM
Slowhawk's Avatar
LS1Tech Sponsor
Your prices are about right.
The $800 for Edit/laptop isn't bad if you plan on changing your setup and tune as you go.You should still tune it on a dyno which will cost some $$.
A dyno tune at a shop is good for people that have a final setup and want's someone to tune it that has experience.....
To bad your not in Ma..I offer Edit tuning for $450 and will do free upgrades to tuning for up to 2 years.So if you changed Cams or added Heads there is no tuning charge,just dyno time if needed.
Old Dec 16, 2003 | 09:46 AM
Scott Turvey's Avatar
I second Slowhawk's comment about getting a dyno tune on top of the edit package. It will be a much quicker and more accurate way of using the edit program, especially if the shop doing it is using a wideband to gauge the changes that are being made.
Old Dec 16, 2003 | 08:57 PM
Got Me SOM's Avatar
Isn't the shop doing the dyno tune using LS1 edit?
If money's not an issue get the ls1 edit yourself, this way you can make changes when you want to.
Old Dec 16, 2003 | 10:44 PM
Slowhawk's Avatar
LS1Tech Sponsor
Yes or no..
You can have the shop dyno Edit tune the car or bring your own Edit and rent the dyno--meaning tune the car at WOT yourself..I highly recommend that even if you own Edit to dyno tune it for A/F.That way when you leave the shop and read your 02's,you will know what voltage ='s the A/F you disire for future tuning.
