lts not going to 0 at wot
Old Dec 17, 2003 | 02:17 AM
2001TA's Avatar
Default lts not going to 0 at wot
How come the LT's are not going to 0 at WOT? Also 02 senser are showing .95-1V at WOT?
Old Dec 17, 2003 | 03:28 PM
mike02ss's Avatar
They are not going to 0 because they are probably + at cruise. This will then cause fuel to be added at wot causing your 02s to be over rich. Check them at cruise and go from there..
Old Dec 17, 2003 | 03:33 PM
jimmyblue's Avatar
Moderator
Positive LTFTs lock in at WOT because the PCM thinks
you'll be unsafely lean otherwise. Then, with that much
extra fuel plus power enrichment, you end up pig-rich
especially if the mixture is closer to right, at higher
airflows.
Old Dec 17, 2003 | 06:10 PM
WicketMike's Avatar
you need to richen up your part throttle using the IFR table. if your ltfts are +5 or so at WOT, do your IFR table by 95% and see how it changes it, monitor it for a day or so and then after that make changes if needed
Old Dec 17, 2003 | 10:28 PM
WS6FirebirdTA00's Avatar
funny, i never saw my ltft's anyhting but 0 at WOT even when my fuel trims were off...maybe they werent off enough. but yeah check the part throttle out, do some sustained driving like where the gas stays fairly constant for about a min of so after driving for 20 min. interstate would work great
