HP Tuner???
Old Dec 24, 2009 | 10:09 PM
craig382ci's Avatar
Question HP Tuner???
I was think about getting a HP Tuner for my 98 SS Z28. To try and tune it once I get the STS kit, injectors, 2 pumps in the tank, bigger feed line, bigger return line, fuel rail, meth/water injection installed and get it stroked over to 408.
But I was told by someone that the HP Tuner will not work on the 98's. That I had to change my cumputer out with a 2000 one. Does anyone know anything about this?
Old Dec 24, 2009 | 10:21 PM
foff667's Avatar
LS1TECH Sponsor
No idea what your friend is talking about honestly, 98's are no problem, we even offer a 2 bar custom operating system for them.
-Bill
Old Dec 24, 2009 | 10:41 PM
craig382ci's Avatar
-Bill
Is a 2 bar what I would need? How hard is it to learn to use?
Old Dec 24, 2009 | 11:07 PM
foff667's Avatar
LS1TECH Sponsor
On a forced induction motor yes I would definitely recommend a 2 bar custom operating system. There is a learning curve, nobodies is the same unfortunately so what was pretty easy for me might not be for someone else, there is alot of reading you'll need to do to learn how to tune either way though, check out our forum www.hptuners.com and help file www.hptuners.com/help which has a lot of good information on tuning.
-Bill
Old Dec 24, 2009 | 11:28 PM
craig382ci's Avatar
-Bill
How much would it cost for this one you speak of?
Old Dec 25, 2009 | 12:38 AM
foff667's Avatar
LS1TECH Sponsor
$649 for the pro mpvi.
Old Dec 25, 2009 | 12:52 AM
craig382ci's Avatar
Would I need to hook up my meth/water injection and my nitrous up to it some way? Or would I just hook everything up normal? I guess what I am trying to ask is would I need to anything special with these items?
Old Dec 25, 2009 | 01:54 AM
macca_779's Avatar
If your going N20 and want to incorporate spark and AFR modifiers into the tune when on the spray then you will need to use a switch and resistor that fudge's the IAT and work around that in the tune. Since you have a 98 your options are a bit limited. The later controllers have a few more options for N20 integration available but only then when tuned with EFI LIVE anyway.
Old Dec 25, 2009 | 04:38 PM
craig382ci's Avatar
What is better for tuning? HP Tuner or EFI LIVE?
Old Dec 25, 2009 | 10:58 PM
foff667's Avatar
LS1TECH Sponsor
https://ls1tech.com/forums/pcm-diagn...-handheld.html
Both have their advantages, we are the only one to offer custom operating systems for your pcm.
Old Dec 27, 2009 | 08:58 AM
macca_779's Avatar
For the older 98's and if you do intend to use a custom os, then HPT is the way to go. If you upgrade to a 99 controller things start to change.
