PO171 and PO174 help...
Old Dec 27, 2009 | 06:16 PM
78novacaine's Avatar
Default PO171 and PO174 help...
ok, so the car is throwing both of those codes, stating a lean condition in both banks. it is NOT throwing a code for either o2 sensor. I have LT's and TSP duals, and the car is untuned. so any suggestions on what might be causing the condition, because i dont have the money to just throw parts at it, IE: new o2's, etc, if i don't have a pretty good idea thats the problem. both o2 sensors are less than a year old btw
Old Dec 27, 2009 | 07:04 PM
v8's Avatar
v8
17,16,15,14,13,12,11 Drvr
your car is running lean, 171 is bank 1 and 174 is bank 2 both codes are system too lean bank 1 and 2, get it tuned.
Old Dec 27, 2009 | 07:19 PM
thanks kevin. i forgot to mention, the car has been down on gas mileage by about 2-3 mpg on average since the SES light came on, and it stumbles a little bit at idle and sometimes in the lower RPM range. i am assuming the mileage is being affected by the PCM dumping fuel in order to compensate for the lean condition? i may be comin to see ya for a tune once i get the break in miles on the transmission so i can go WOT again
Old Dec 27, 2009 | 08:18 PM
95_transam_lt1's Avatar
good chance the o2s are bad because the coating from the headers kills an o2 sensor as it breaks in. Use a multimeter on the dc volts (0-1v) and see what it reads. It should bounce around from 100-900mV. o2 sensors usually fail low (lean)
Old Dec 27, 2009 | 10:10 PM
v8's Avatar
v8
I bet lol, good deal see ya soon.
