Check out my logs... I'm getting horrible MPG. Any ideas?
Both of these logs were after a couple mile trip on NEW 02s... I've been through about 5 02s in the last couple months, and the car has barely been driven... Plugs were changed when the problem started a couple months ago as well. The car has 42lb green tops. I'm getting 6-7 mpg.
I can't read the log. Do you have the correct IFR values in the tune? If the car ran fine before the plug swap, I would recheck all of the plugs and wire connections to make sure they're on correctly.
I'd say you got a major exhaust leak just going by the logs. Are the injectors a matched set? Send me a copy of your tune and I'll look thru it and see if I can see something that you may have missed, if you want.
Sorry for taking so long to get back guys, I appreciate the replies.
Yes, I'm tuned for the injectors, the tune was done a couple yrs ago, and the specs werent out for the injectors yet, so it was kind of "estimated".
Also, the plugs/wires were double checked.
The injectors are a matched set.
I cant figure out how to post the tune... Any advice is appreciated!
