how much timing?
Old Jan 22, 2010 | 08:34 AM
bonnarls1's Avatar
Default how much timing?
i have 416 ls3 225 afr bigbore heads 11:9 compression 90/90 fast 2" headers
3.5" to 4" exhaust running on 93 octane how much timing can i run?
Old Jan 22, 2010 | 11:59 AM
WeathermanShawn's Avatar
Hi there:
Looks like a nice build.
That is a pretty open-ended question, and is very difficult to just 'guess' at a number.
I will ask the obvious question. Can you get to a dyno? I would imagine that to properly tune that beast, you would had to dyno tune it anyway.
WOT Timing really takes some dyno time. Perhaps with that CR, you might only need 22 degrees of timing at WOT. That is just a wild guess on my part.
Hopefully you will get some more responses from people with a similar setup..but they might tell you the same thing..tune it..
Good luck..
.WeathermanShawn..
Old Jan 23, 2010 | 07:48 AM
bonnarls1's Avatar
Originally Posted by WeathermanShawn
Hi there:
Good luck..
.WeathermanShawn..
i did some wot tuning on the street with a wideband and hptuners 22 degs
work good so i try 26 and i got some dentenation. i have a couple friends that have 427 with 12 to1 cr and they can get 26 degs on pump gas!!
Old Jan 25, 2010 | 02:09 PM
HUNTER02SS's Avatar
Every set up is different. One piece of advice though would be when adjusting your timing tables, do adjustments in 1 degree increments.
Also there is a few other tables that influence your overall timing. You need to make adjustments to them as well.
Old Jan 25, 2010 | 02:50 PM
jimmyblue's Avatar
Moderator
The point is not "how much can I get away with".
It's "how much doesn't give any more benefit".
There's a fair gap between MBT and ping, as little
as a couple degrees, but likely more.
This is where a dyno or an accelerometer you can
log, is useful. You run a few pulls with a series of
timing maps and you pick the "best answer" point by
point (going by best acceleration vs road speed,
what RPM and CylAir was that, update the table in
that cell) and stitch it together.
Keeping in mind that more spark than helps, is only
going to be ping-potential when warmer weather or
aging comes around.
Old Jan 29, 2010 | 05:06 AM
Sid447's Avatar
Smile
....i have a couple friends that have 427 with 12 to1 cr and they can get 26 degs on pump gas!!
More isn't always better.
I agree 100% with the above post (#5).
The better the engine is built the less total timing required.
The minimum required timing to get to MBT is where you need to be.
Old Jan 29, 2010 | 11:26 AM
Slowhawk's Avatar
LS1Tech Sponsor
aging comes around.
I agree.This is when a dyno comes in very handy.The car could make the same power at 20 degree's of timing than when it's at 26 degree's. I don't trust knock sensors.
