Wideband ?
You're best bet is to spend the extra money and get a quality wideband like the NGK AFX. It comes with a display. The best part seems to be not just increased accuracy but much better control over the heating circuits, resulting in many fewer O2 replacements.
I went through two sensors on the LC1 and two on a FAST unit, but have yet to actually go through one with the AFX (although I did order an upgraded sensor).
I understand if money is an issue, but if you're going to tune with it and not just use it for safety (lean conditions in general), you need quality. Also, using two widebands is almost a waist, unless you setup a custom PID to average them, since the LS series cannot be programmed to trim fuel on an individual bank basis.
I havent had any issues with the LM1. You do have a buy a serial cord to adjust the offset between the LM-1 and the HP tuner.
Its easy to do and only takes a minute. The extra cord was about $12.00 at office deport.
If you can, swing for the NGK sensor, but if not it's still accurate with the Bosch. Only other thing is that although the sheath is heat resistant, it WILL melt if it is pulled tight to the exhaust.
