Help, P0102, How To Fix
Old Dec 22, 2003 | 10:08 AM
Matt B 991LE's Avatar
Default Help, P0102, How To Fix
Im having a issue with my stock Maf, I let a board member borrow it and when I put it back on I threw a code (P0102 low voltage) and Im assuming the wires inside are shot. Ive reset the PCM twice and nothing is working, any Ideas? Should I try a new MAF? TIA.
-Matt
Old Dec 22, 2003 | 08:40 PM
wrencher's Avatar
wrencher
First thing to check, the "sensor" fuse in the under hood fuse box.
Old Dec 22, 2003 | 09:13 PM
ss rally red's Avatar
Did he use a reusable filter/ K&N/Holly? If so clean the Maf wires with Choke/Carb cleaner and a q-tip with very light pressure and see if that takes care of it.
Old Dec 22, 2003 | 10:12 PM
WicketMike's Avatar
and also are you sure its "yours" you got back
Old Dec 23, 2003 | 07:38 AM
Thanks, I got it figured out!
