VE Edit Table and ChrisB's Log Analyzer (long)
Old Dec 27, 2003 | 10:28 AM
Bink's Avatar
Default VE Edit Table and ChrisB's Log Analyzer (long)
I'm creating a new VE table, for my setup, using NoGo's and ChrisB's method.
I'm almost "there" with about 37000 valid frames. I still need to hit some low RPM/ low map cells (below 1600RPM) and high RPM cells. It's pretty exciting to see the new table develope ...especially the " MAP v RPM v VE " graph.
When I import the Logfile into ChrisB's Log Analyzer I have to change/uncheck the percentage VE value and the 100% value (2500 ->3000) each time. How do I change the default??
Should the 3D VE graph "SendKey" be functional?? Mine isn't.
My most important question - How do I get it to transfer the Log Analyzer VE Table to one of my LS1Edit files???
When I select the LS1Edit file the Analyzer then writes/rewrites the data. It then askes how I would like to save it,... Text-Tab Delimited etc? Regardless, of how I save it, I'm unable to open it with LS1Edit or LS1Prog.
It looks like the IDs from cell 1A have been stripped by the Analyzer. Actually, when I open the new file with Excel it looks like some of the "Russian Alphabet" is missing! I copy/pasted the first cell but it still says 'Tuner PCM"
Has anyone else had this problem?? What can I do to remedy ( Remedy - an excellent Black Crows song) it ?? I hate to have to transfer this the old way - manually- when I'm so close.
I'm using Edit v1.31H.....I have v1.2 loaded also.FWIW.
Thanks guys.
joel
Old Dec 27, 2003 | 02:11 PM
ChrisB's Avatar
I stopped doing anything with the program with Ken finally added cut and paste in V1.3 - you can just open up your text files in excel then cut and paste into ls1 edit. The sendkeys should work - it works with v 1.2 anyway.
It doesn't save the default settings, you would have to change those everytime. It definitely isn't a finished program, but with cut and paste added to ls1 edit I didn't have as much use for it. If anyone wants to play around with it I would be more than happy to send out the source - but a fair warning, this was my fist VB project so it is a bit ugly
Old Dec 27, 2003 | 09:27 PM
Bink's Avatar
Thanks Chris. Cut and paste works for me. I don't think this is ugly at all!!
I like the way it makes things look
joel
