needing a hptuners bin for 5.3 turbo
hey guys post em up if you have any...car is a 98ta with 5.3 and a 78mm turbo 42lb inj with 70 psi so they are like 58's i think....car is 2bar speed density....got it started and its not flooding but think i leaned it out to much once it starts getting into boost....ill post up my file when i get home and you guys can tell me what you think thanks....
how do i go about changing that? car also idles about 1600rpm in gear or not....kinda new to this and looking for some answers....think i have the fueling issue about taken car off.....i noticed that the afr went to like 10.0 when it got into boost so i pulled some fuel and got it to boost 5lbs so i think im heading in the right direction....but point me in the right direction on the idle.....tune is uploaded above
