Wideband AFR Problem?
At idle it would sit anywhere from about 12.5 - 14.3 or so. Car is a head/cam car so I expected it to vary a little. That's expected correct?
At WOT it would be around 12.6-12.9 or so. That is also good, isn't it? Car is tuned so it should be good.
But every once in awhile my car will seem to hesitate and seems like it loses all power. I got to see what the AFR was doing while it did this. So I'll just be cruising and it will seem like it loses power and cuts out a little. The wideband went straight to 24.4 when it did this? So it's running real lean when it starts missing? This seems real strange and I have no clue what it can be. But when it starts missing a little you can just punch it and go WOT and it cleans right up and goes to 12.6-12.9 or so. What is going on with this?
I'm not sure about LTFT's how do I check this?
I just know something is still wrong and I can't locate it. I mean I even switched my passenger o2 to the driver side when it said it was bad and it didn't correct when I installed my wideband. It may be the ext. harness is bad. I probably just need to go get one of those corvette o2 sensors and install it and take it back if it doesn't fix it.
When I start the car up and only on startup it will run good for like a few minutes. Then all of a sudden all kinds of powerloss and change in the motor tone. Wideband goes to 22.4 and sits there except when you shift gears and for a split second it fixes then starts doing it again. I also heard this real loud sucking noise near the intake when it was idling and doing this today. Is the MAF doin this? It was like a real loud noise that sounded like it was sucking air in. But the strange thing is all of a sudden after driving it for like 5 minutes the car just clears out and runs perfect and doesn't do this anymore until you turn the car off no matter if it's warm or still cold. It will startup and then after a minute do the same thing and then fix and not do it again. I'm completely stumped... and want to run it into a lake.
I'm trying to understand what tapping the MAF will accomplish??
502 Rules!
If you have a copy of HP Tuners or EFI live use your wideband to calibrate the MAF. Follow the Greg Banish DVD step by Step!! So ppl recommend using the the LTFT's to calibrate the MAF but if you have slow sensor response (Cold Sensor's), the LTFT route is a waste of your time. WIDEBAND CALIBRATION FTW!!!
