hptuners wideband offset
If this is because of ground offset and i make a jumpper harness that ties the obd2 ground together with the ground in the cig lighter im using to power the wideband it should do away with this problem for sure? I thought about just modifing the transfer function in hp tuners but it seems the the amount of this ground offset could be different in different vehicles, id like to find a solid solution.
any other solutions?
WBO2 Expressions.xls
Even with my stft's at +/- 1, the wideband was off by about 10% everywhere.
I'm guessing because I have it powered by the accessory outlet.
I wasn't sure if it was ok to "calibrate" the wideband through HPTuners...
