First I had a P0135 code, changed the O2 and now I have a P0171??
Hey guys, I had a P0135 code in the Z so I bought a new Bosch O2 sensor and just swapped it out 30 mins ago. Cleared the code and went for a 5-10 min drive around the neighborhood.
During lower RPM cruising it kinda spudders, but at idle and during accel everything seemed fine. Came back home and I have a P0171 code now that I've never had before.
Ideas?
Thanks!!
Ideas?
Thanks!!
If it were the MAF, I should be getting codes for both banks, correct?
Okay, cleaned the MAF, checked for vacuum leaks using both parts cleaner and the smoke method, no dice.
It gets better, I cleared the codes, then I went for drive. Still runs like ****, rechecked the codes and now my P0135 code is back along with P0171....
Faulty O2?
Faulty O2?
