Timing for a 6.0 with Trex
Old Apr 2, 2010 | 03:05 PM
NOPANTS-68's Avatar
Originally Posted by Goldfinger911
Check the difference the idle cells in your base timing versus your low/high timing. If there is a difference, once the throttle opens you will get a stumble when going WOT from idle.
not sure what you mean with regards to the high/low timing cells.
Old Apr 5, 2010 | 12:52 AM
JDMC5's Avatar
he's talking about transition from your idle spark tables to your high/ low octane tables. It should be a smooth transition to keep the timing from jumping around.
Old May 8, 2010 | 03:16 AM
LSxPwrDZ's Avatar
I've not messed with the MSD timing controller but the things you guy's are telling him to do is in a factory PCM... this guy's stuff is carb'd with a MSD box controlling the coil packs not a factory PCM...
