hp tuner ?
Old Mar 29, 2010 | 10:38 PM
scites's Avatar
Default hp tuner ?
ok so i got HP tuner the other day and was playing withmy car, the old tune had the 3.42 gears from my 10 bolt andi swopped to a 9in with 4.11 gears. so i changed that in the program and then i played with the spark and fuel tables..what do you guys have your stoich at? what is good or bad? mine was set at 14.7 and i went to 13.7..just changing that and the gears the car feels a lot better..and my idle was at 1150 i lowered itto 1000 ..what the hell does the smothing button dur for the histigraphs? i know if changes the numbers around a little..fill me in..lol..im retarded
Old Mar 29, 2010 | 10:44 PM
sidewayz28's Avatar
go to HPtuners. you need to know what your doing before you start adjusting random tables. I suggest getting Greg Banish's book off of Amazon. Or MAS motorsports beginner guide which actually gives you an idea as to what you need to do. Stoich is ~14.7
http://www.hptuners.com/forum/showthread.php?t=4742
READ, READ, READ, READ, READ, & READ.
dont just blindly change ****
-Do you have a wideband?
HPTuners is NOT easy, i gave up on it for a while. The learning curve is S T E E P
Old Mar 30, 2010 | 08:19 AM
scites's Avatar
ya after i played with it and posted this thread i read that stoich is supost to be close to 14.7 dependingon fuel so i changed it back
