TPS codes and problems along with rear abs sensor??Need help!
Conditions for Setting The DTC P0123
- The TP sensor signal voltage is more than 4.75 volts.
- The condition is present for 10 seconds
- The TP sensor voltage is more than 4.8 volts.
- The intermittent condition exists for a total of 1 second during a 20 second period
- The TP sensor voltage is less than 0.2 volts.
- The intermittent condition exists for a total of 1 second during a 20-second period.
- Disconnect the harness from the TPS sensor and check for signs of arcing (black "soot" on the bare metal connectors). Use a very small flat screw driver and carefully close or press together the sides of the female connectors, taking care not to damage anything. Blow out the connectors with compressed air to clean any dirt or debri.
- Did you happen to do the bumpstop mod? Sometimes grinding too far will cause the TPS volt to read excessively high and setting a code.
Hope this helps.
Hope this helps.
