Efi Live
Old Jan 7, 2004 | 08:31 PM
Red01Chevy's Avatar
Question Efi Live
is there any real difference between efi live V5 and V6 the pro version.
Old Jan 7, 2004 | 10:03 PM
jrp's Avatar
jrp
SN95 Director
http://www.efilive.com/downloads/featuresv6.html
and if you have v5 already the upgrade to v6 is free so its not like your loosing out :shrug:
Old Jan 8, 2004 | 09:53 AM
Red01Chevy's Avatar
if the upgrade is free then why is the V5 version $350 aned the V6 version like $500. i dont have any of them im just getting started so i am really confused just tryin to get all my ducks in a row
Old Jan 8, 2004 | 09:55 AM
Red01Chevy's Avatar
what is the difference between the V1 and V2 cable
Old Jan 9, 2004 | 08:33 AM
dissonance's Avatar
V1 cable is slow "logging" V2 cable is at the serial ports full speed "you can log more then one item with out a delay or not much of one" I don’t think you can even buy V1 new anymore
The price difference is Professional vs. Standard
Professional Software with cable is $500
Standard Software with cable is $400
Difference in the two is Bi-Directional Controls… this is good to test a setting before you program it in to the PCM.
Some screen shots of bi-directional controls
Old Jan 9, 2004 | 02:16 PM
EFILive's Avatar
Restricted User
I guess there are still V5 versions that some distributors still have in stock - if you do manage to get one, then it's a "cheap" way to get V6. Because you can upgrade from a $350 version of V5 to $499 version of V6 free.
Once all the V5 stock runs out then V6 wil be the only version you can buy.
Regards
Paul
Old Jan 9, 2004 | 02:19 PM
EFILive's Avatar
Restricted User
As Dissonance said the V2 cable can log at 115,200 baud, the V1 cable is limited to 19,200 baud. However, when using EFILive's 10x24 scan mode that baud rate limitation makes no difference. So the V1 and V2 cables can both log up to 24 parameters at 10 frames per second.
Only when using Dynamic packet or single PID logging does the baud rate setting make a difference.
The significant difference between the cables is that the V2 cable supports bi-directional controls, the V1 cable does not.
Which, by the way, is also the difference between the Std and Pro versions.
Regards
Paul
