TPS and MAP Signal Voltage Low
Here is what I found after checking sensors:
TPS: 5v between grey and black (ground)
Blue 0.16v to 2.2v (NOT CORRECT!) swapped sensor, same result
MAP: 5v between power and ground
Light Green: 2.2v with key on (back-probed sensor)
It seems as if my sensor signal wires are giving the PCM a much lower signal that what it is required.
I am getting 5v and ground from PCM
Also, removed IAC motor with wiring plugged in, turned on key and the pintle fully extended out (as to shut off all airflow). Is this normal?
I ran a dedicated ground from the engine to battery - no difference.
