LS2 Vats ?
Old May 9, 2010 | 10:56 AM
kochevy67's Avatar
Default LS2 Vats ?
Will a LS2 with the VATS not deactivated have spark to the motor or not. I am trying to start the car and was wondering if the car will start and run for a few seconds then die. Can you spray carb cleaner to see if it will fire? I still haven't had the computer programmed yet. I wanted to see if I have everything wired correctly first.
Thanks.
Old May 9, 2010 | 08:14 PM
kjhallex's Avatar
I think it will start for a few seconds and then die.
Old May 9, 2010 | 08:54 PM
kochevy67's Avatar
Thought so myself so I guess I left something out. Thanks.
Old May 10, 2010 | 11:30 PM
racecar's Avatar
Yes, it will start and run for a second then die, as many times as you want to try it.
Old May 11, 2010 | 08:27 AM
kochevy67's Avatar
If that is in fact the case I really need to fing out what wire(s) I don't have hooked up to power the coils. I am going to have the ECM reflashed today and start from there.
Old May 11, 2010 | 08:52 PM
squarehead's Avatar
fairly certain VATS on the LS2 GTO PCM..... cuts at least spark
Old May 13, 2010 | 11:57 PM
kochevy67's Avatar
Thanks for all the support. Had the ECM flashed and it is up and running. Hell yeah. By the way the vats killed the spark for anyone thta has a uture problem like I did.
