Converting to a 1 wire O2?
I want to use the 1 wire sensors because they are way cheaper, and 1 wire is obviously easier to add to a harness than 4. The heater in the modern oxygen sensors is just to bring it up to temp quickly for emission purposes right?
If you're running headers, even a heated sensor may
not be happy at idle. So expect some poor trimming
behavior unless you have it mounted close-in to log
style manifolds.
