Need LT1 OBD1 A4 Shift help please. Datamaster file
Old May 21, 2010 | 07:20 PM
PoorMan's Avatar
Default Need LT1 OBD1 A4 Shift help please. Datamaster file
Good day. I am working with a 1995 Z28 A4 stock block with only a sts turbo and a 2800 stall. Car seems to shift 1-2 fine but 2-3 and 3-4 are not right. Lots of rpm and no increase in speed. Like it's slipping. Any suggestions? I installed a stock 1995 A4 flash that Shoebox had posted.
Btw, the car shifted fine before I switched back from an OBD2 to an OBD1 computer. I switched so I could tune with tunercat I have and do not wish to revert.
Datamaster file:
http://www.mediafire.com/?ztjynn3tw0n
Thanks for any help.
Old May 22, 2010 | 07:10 AM
flame's Avatar
The OBDI pcm is not as fast so the pressure may be slightly lower when running it. Sounds like your 3-4 clutch pack is likely on its way out though.
Old May 23, 2010 | 12:53 PM
PoorMan's Avatar
Car shifts fine with the obd2 computer so I know the trans is fine. Needs a guru to look at my datamaster file. The bin is a competely stock 95 a4 3.23.
Old May 23, 2010 | 08:39 PM
boosted LT1's Avatar
PM me I have a rearmount and front mount LT1's so I think I can help you
