What is the HP tuners parameter for Speedometer PPM setting?
Old May 25, 2010 | 09:22 PM
Berto's Avatar
Default What is the HP tuners parameter for Speedometer PPM setting?
So the only thing left on the LS1/RX-7 swap is to get the speedometer working.
I am wondering what the paramter is in HP tuners that changes the speedometer PPM output?
The PCM already has my tire size, and rear end ratio input correctly. Heck when I have a scanner hooked up the speed sensor output is right on with my GPS. However, the speedometer is not reading right.
I got another speedometer and it reads the same.
can someone help tell me what the parameter is so when I take the car to get tuned I can get it fixed?
Thanks!
Old May 25, 2010 | 10:49 PM
jeff2380's Avatar
Is your gauge cluster or speedo for the same car as the PCM your using?
Old May 26, 2010 | 11:23 AM
Berto's Avatar
That doesn't matter if there is a parameter to adjust the PCM's ppm output.
But if you must know. Its a Honda Integra Speedometer in my RX-7 Cluster. originally the RX-7 speedometer was mechanical which is why the Integra electronic speedometer had to be retrofitted.
Several others have used it with great results.
Old May 30, 2010 | 10:54 PM
Berto's Avatar
Bump, anyone?
Old Jun 3, 2010 | 11:56 AM
Berto's Avatar
bump again, no one knows?
Old Jun 3, 2010 | 09:19 PM
scottknight's Avatar
I am confused about how you could edit the tire size and gear ratios and not see it. It's clearly right there in the Speedo editor marked "VSS Output Pulses per"
Attached Thumbnails What is the HP tuners parameter for Speedometer PPM setting?-speedo.jpg
