Can anyone recommend a stand-alone harness for 12586243
I am looking for a company that makes stand-alone harness for my PCM 12586243. That is, a harness with an integrated fusebox so I don't have to use the OEM one.
It's the PCM 12586243 which uses the green & blue connectors.
Jeff
Jeff
Yep..
I opted for the nylon mesh covering.[$100]. I like it ALOT better than the convoluted plastic stuff. [Easier to route].
Everything is labelled, and looks to be a HI Q piece.
In order to "smoke test" everything, I hooked it up to all the sensors w/ the engine and trans on stands.[LQ4/4L60E]
I had my lt and EFILIVE booted, and plugged in.
I powered it off a car batt w/ jumpers, and keyed it on.
All sensors, and the DBW worked as it should...
An easy way to help avoid problems when installed in the car..
http://www.howellefi.com/customer/
