which would be better?
Old Jul 7, 2010 | 01:27 AM
6LiterHawk's Avatar
Default which would be better?
so i am finishing up on my lq9 swap into my 2000 firehawk, just wondering if i should use the 28lb. injectors that came with my ls6 intake manifold, or if i should use the ones that came on the lq9, i wont be able to get a tune for a little while after i get it done. was just wondering if the stock tune would work with the 28lb. injectors or not.
Thanks
Old Jul 7, 2010 | 05:29 AM
BLK02WS6's Avatar
I believe the LQ9 injectors won't hook up - the connectors are different. The 28# injectors will be fine till you get it tuned... go easy on it till you get it tuned though.
Old Jul 7, 2010 | 02:53 PM
6LiterHawk's Avatar
alright thanks, would i be better off using the stock ls1 injectors till i get it tuned?
Old Jul 7, 2010 | 05:40 PM
BLK02WS6's Avatar
Your 2000 came with 28# injectors as well, so it doesn't matter... I looked at a stock 2000 tune to double check, and it is set for 28#ers.
