Rev limiter?
Old Jul 18, 2010 | 01:58 AM
00fxd's Avatar
Default Rev limiter?
I have a transplanted '03 LQ4. Stock wiring, pcm etc. Mail order tune/re-flash to remove vats, set wheel dia, gear ratio and remove auto trans and A/c stuff. Does this pcm have a rev limiter? The engine shuts off dead at about 5800rpm. I have sent it away twice to the tuner now, the first time he hadn't removed the shift managment that retards ign timing @ 5000rpm to smooth shifts. Maybe there's a rev limiter should go too?
Thanks, Frank.
Old Jul 18, 2010 | 07:58 AM
69LT1Bird's Avatar
Yes, the PCM has a rev limiter. If you are stock, why do you think you need it raised?
Old Jul 18, 2010 | 10:59 AM
flame's Avatar
Whether its cable or drive by wire all the tables have to match to raise the limiter. Possibly he missed changing all the tables.
Old Jul 18, 2010 | 12:12 PM
00fxd's Avatar
It's quite happily pulling away when it shuts off. I understood that these engines were capable of lots of RPM/power to the stock bottom end. Am I wrong then to rev it higher that that without better rod bolts etc?
Old Jul 18, 2010 | 12:41 PM
69LT1Bird's Avatar
If the cam, heads, intake, etc. have not been upgraded the engine is not making anymore power so it doesn't make a lot of sense to rev it for no reason.
Old Jul 18, 2010 | 10:30 PM
00fxd's Avatar
Thanks Bird, I do agree with you, but this engine is still pulling when it shuts off. As I understand it, this bottom end is good till substantially more Horse power and RPM. Down the road I may upgrade to 243 heads, upgrade cam and intake. Am I asking for trouble with the stock '03 LQ4 rods? The '04s LQ4's got the stronger LQ9 rods.
Old Jul 19, 2010 | 06:10 AM
69LT1Bird's Avatar
The metallurgy of the rods I believe is the same, they went from fixed pin to floating pin to try to fix the piston slap issues. Stock rod bolts. from what others have said are good up about 6300-6500 rpms of continuous beating.
If you are not making anymore horsepower there is no need to rev it any higher. If you had it on a dyno, the peak is probably about 5000 rpm range, maybe. The trucks are set up for low end torque, not high rpm horsepower.
Here is a link to the stock specifications from GM.
2004 LQ4 Specs
Old Jul 19, 2010 | 01:47 PM
00fxd's Avatar
2004 LQ4 Specs
Thanks again bird. I still wanna shift when I wanna shift... Again mine is an '03.
Can anyone else please verify that I can shift this stock bottom end up to 6 or 6500 rpm at some point down the road?
Old Jul 19, 2010 | 02:14 PM
2xLS1's Avatar
Stock 03 LQ4 cals have the rev limiter set at 5700. Yes with tuning software you can set it higher. if you want to set it higher than 6200 I would at least put a set of LS6 valve springs on it.
Old Jul 20, 2010 | 03:04 PM
00fxd's Avatar
Springs sound like a good idea, That is something that I'll make sure of with the 243 heads.
Old Jul 21, 2010 | 12:55 PM
wait4me's Avatar
on the 2003 there are a few limiters, some are at 5900 and the rest are at 6000. If he dont get it figured out, you can send it to me and ill fix it for you at no charge. Just cover shipping.
Old Jul 21, 2010 | 10:57 PM
00fxd's Avatar
A gallant offer to be sure, thank you very much. I'll send you a PM..
