im getting come gay codes after 98 to 02 pcm swap.
Exclamation Ever since i did my 98 to 02 pcm conversion i get the following codes.
its making me nuts.
p0121 p0102 p0135 p0141 p0155 p0161
any ideas?
the tps code i have an idea it can be the throttle position sensor. it should read at .4 when foot is off the gas on idle. but it reads 0% am u correct in assuming it should be at .4?
please any info would be greatfull. i need these codes off of my pcm its driving me nuts with the ses light on.
any help would help please please.
its making me nuts.
any ideas?
i want to update that i checked the engine sensor fuse in the engine bay and it was shot. i changed it out. ill drive the car tomorrow and see wahts going on.
p0121 -Throttle Position Sensor/Switch A Circuit Range
p0102 - Mass Air Flow (MAF) Circuit Low Input
p0135 - 02 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
p0141 - 02 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)
p0155 - 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
p0161 - 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
I'm guessing it's a wirng problem
Yeah who cares about the O2 sensor stuff just disable all that run open loop speed density then you only need to sorry about the p0121 error
... or fix the wiring and run open loop speed density anyway...
