SLP Predator help!
Old Jul 21, 2010 | 12:36 AM
calcamLS1's Avatar
Default SLP Predator help!
I have a Slp predator...im having trouble with the transmission shifting to early on the 1-2 shift at WOT... it begins to shift at 5300rpm and completes the shift at 5600rpm...im stumped on how to get it to shift right around 6000rpm to be able to use the extra power...any help would be appreciated because im going to the track this saturday and need to figure this out....Thanks!
Old Jul 21, 2010 | 08:38 AM
calcamLS1's Avatar
no ideas?
Old Jul 21, 2010 | 11:11 AM
Mike@Diablosport's Avatar
LS1Tech Sponsor
Does it shift the same way with the stock tune?
Have you tried raising the WOT shift points?
Old Jul 21, 2010 | 12:56 PM
calcamLS1's Avatar
it has the modified stock tune in it...the shift rpm is set to 6000rpm and the mph i tried adjusting but that had no affect... im at a loss at why its shifting so early?
Old Jul 21, 2010 | 12:59 PM
calcamLS1's Avatar
is the computer shifting it earlt because the first gear is so low is 4l60e transmissions?
Old Jul 21, 2010 | 02:09 PM
LS1Tech Sponsor
With the modify stock tuneit will shift at the same time as the stock tune unless you change it...have you confirmed where it shifts with the stock tune installed?
Have you tried logging it to make sure it is not a slow tach issue?
Old Jul 21, 2010 | 04:37 PM
calcamLS1's Avatar
no i have not tried that? . . . how do i do that? what will show that indicates that?
Old Jul 23, 2010 | 06:22 PM
calcamLS1's Avatar
alright i data logged it with the genisys scanner at work...slow tach thanks guys! wish me luck at the track tomorrow'
Old Jul 24, 2010 | 07:47 AM
06MonteSS's Avatar
LS1Tech Sponsor
excellent!!
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
