Help with my Tune, check out the logs
Old Jul 27, 2010 | 04:30 PM
gjohnson's Avatar
Default Help with my Tune, check out the logs
Ok, well I posted this on the Efi Live forums and thought it would be best to just link to the site since the Logs are already attached.
Here's the deal, I just switched from a 04 GTO PCM to a F-body 411 PCM so I would be able to install A/C on my swap. My tuner copied over all the tables and such for the tune, but now with the 411 PCM installed the Car won't rev over 1600RPMs. I'm trying to figure out why so I did some data logging. Thanks for any help.
Copied form the other thead:
I guess I missed some steps, I tried using the little paperclip function, but no dice. Oh well ...........Attachment 8644Attachment 8643
The 1st log was done right after startup and I did multiple attempts to rev the engine over 1600rpms.
The 2nd log was started before the startup so you could see how high it revs on startup and then I let it rev and idle until the temps where high enough to turn the 1st fan relay on.
Edit: I'm not sure if the links to the logs above will work since they are from the Efi site, so here is the link to the thread. Thanks for any help.
http://forum.efilive.com/showthread....ng-wrong/page2
Old Jul 28, 2010 | 09:24 PM
gjohnson's Avatar
Anyone??? If the car was in abuse mode, wouldn't I have a MIL light or be able to see that in efi somewhere??
What would cause the car to go into abuse mode besides the VSS. The VSS should be correct, it has the same pins on GTO pcm and F-Body PCM and it worked fine with the GTO PCM for 5 months. Thanks for any help.
Old Jul 29, 2010 | 05:35 AM
BLK02WS6's Avatar
Post up your tune file here...
Old Aug 17, 2010 | 08:53 PM
gjohnson's Avatar
There's alot more info on my problem here.
http://forum.efilive.com/showthread....-I-doing-wrong
Also, I think the tune is posted in the link above.
Old Aug 17, 2010 | 09:34 PM
coD's Avatar
coD
Replied on efilive forum
Old Aug 17, 2010 | 09:46 PM
xBRadX's Avatar
What were the results of the engine segment swap that Ute did?
Those guys are good over there. I'm sure it will get sorted out.
Out of curiosity, what is it about the F-Body PCM that will allow you to run A/C and the GTO PCM won't? Aren't they both 0411's?
Old Aug 17, 2010 | 09:53 PM
poconojoe's Avatar
No the 2004 GTO is a 6243 and it uses the BCM for the low speed fan function and the AC request
The first segment swap UTE did, had the same results, the second one Grant hasn't recieved yet, since we were looking at some other issues first
Old Aug 18, 2010 | 02:11 AM
joecar's Avatar
Default Thinking Out Loud...
The only things I saw set to 1600 rpm were B1201/B1203 (abuse management upper threshold IG/PN)...when rpm exceeded B1201 or B1203 then AM enabled (this would allow rpm to swing upto 2300)...
his log showed EQR 1.047-1.061 when the rpm was swinging between 2310 and 833 (with IBPW not cutting to zero)... in the tune file the AM commanded fuel is EQR 1.05, and I couldn't see any other commanded fuel in this range...
Now, if AM is enabling then the PCM/file thinks it is for an AT...
so hopefully the second file starts from a manual trans file and swaps in the engine segment.
