injector bank issue
Old Jul 31, 2010 | 12:37 PM
fmowry's Avatar
Default injector bank issue
I've got an LS6 swap in an Miata controlled by an '04 GTO PCM with a vanilla mailorder tune to delete the basics. I figured I'd pick up HPtuners to see what the hell is going on.
The problem is the bank 2 02 drops down to zero and ST goes through the roof while the bank 1 02 gets pegged.
I checked for spark and the coil packs look OK. I decided to pull the injector clips one at a time and if I pull a clip on either side and then reconnect it the problem seems to fix itself, at least for a while.
Attached is the *.hpl showing the whacked out 02 and fuel trims and then showing them settle down when any injector is disconnected then reconnected.
Any ideas? Bad injectors? Should I swap bank 1 injectors for bank 2 injectors and see if the problem switches sides?
Thanks,
Frank
File Type: hpl
Old Jul 31, 2010 | 03:50 PM
fmowry's Avatar
Swapping bank 1 injectors with bank 2 injectors did nothing.
Old Jul 31, 2010 | 04:56 PM
Old Geezer's Avatar
Engine been sitting for an extended period of time, B4 U started it??
If so, injs could be gummed up..I see this frequently, when I clean/flow injs for the local j/y....
Old Jul 31, 2010 | 05:02 PM
fmowry's Avatar
It has. But wouldn't swapping the all 4 pax injectors to driver side and having the same issue with the pax O2 indicate it's not an injector issue?
Old Jul 31, 2010 | 10:11 PM
Bird's Avatar
Sounds like maybe you have the O2 sensors plugged opposite - swap them at the plugs and your problem should go away.
Bird
Old Jul 31, 2010 | 10:35 PM
fmowry's Avatar
I think I see what you mean. Swap the actual plug wiring on the same side. Will try.
I did replace an O2s before from an OEM from Denso to a univeral where I had to wire in the plug. But after I swapped them side to side there was no difference.
Rockauto has denso OEMs with plug at 37 so I'll pick up a couple just to have and try but I doubt this is the issue.
Frank
Last edited by fmowry; Aug 1, 2010 at 11:04 AM. Reason: drunk posting didn't make sense.
Old Aug 1, 2010 | 06:07 AM
Old Geezer's Avatar
Talking Whoops!
Bird
hadn't thot of that!!.. Getting old is not all it's cracked up to be!!
I now recall we had a Vette that had the plugs swapped...Same thing.
Old Aug 1, 2010 | 03:32 PM
fmowry's Avatar
Duh, finally understand. Swap B1 plug with B2 plug. I shouldn't read the forum at 1am afte having a few too many beers!
Thanks,
Frank
Old Aug 7, 2010 | 10:58 AM
fmowry's Avatar
Bumping this. Swapped leads and the problem swaps banks. O2 lead wiring problem?
Guess I'll check continuity on Low and High.
