LS1 EDIT HOW DO I LOCK UP MY converter
Guest
Posts: n/a
under trans cal, tab a4 tcc there is true/false for tcc lock during shift. as far as pressure, i'm guessing you want firm up the shift. i read my pcm with hpp111 set to firm it up, then read stock. copied tables. the change was in positive pressure vs. temp table, the avg. change was about 100 less from the 6 column to the 72 column. i can send you these two files to compare if you want. it will give you an idea of how it's done if not the actual numbers you need. pm me if you want them. e
