ls1 frankenstein help!!
Old Aug 19, 2010 | 03:42 PM
rexrunner's Avatar
Default ls1 frankenstein help!!
HELP ME PLEASE
i have an LS1 from a ws6 with approx 21k miles on it.
pcm is from a ls1 99-04
t56 from a ssr before the 6.0 (ls2)
throttle pedal from a corvette with tac module
harness is http://www.painlessperformance.com/w...rchAll=Customs
the problem is I have a tb from a 03-07 truck it has a 8 pin connector like below
and the harness has a 6 pin and 2 pin
can i make my tb work? or shoild i buy a older vette or truck tb? also which reflash is best, original map on pcm is for throttle cable not dbw
help please, this is my last bump hopefully
Old Aug 21, 2010 | 08:25 PM
NoGo's Avatar
Can you make that setup work with a soldering gun and some electrical widgets...probably. Do I know how....no.
But if I was in your shoes I would check the PCM Part # against what the harness is pinned for (painless lists this). If they don't match change one. Following this I would get a different TB to match the harness suitability.
By Brett Foote | 2026-06-04 05:00:17
