base tune
Old Aug 26, 2010 | 04:24 PM
2000RDT/A's Avatar
Default base tune
just about to go pick my motor up from the machine shop. had h/c installed. who would you guys recommend on a mail order base tune?
Old Aug 26, 2010 | 04:45 PM
Z28camaroLS1's Avatar
Steve@Tunedbyfrost.com is the man to go with. Trust this guy you won't be disappointed
Old Aug 26, 2010 | 06:16 PM
BLK02WS6's Avatar
Steve is a great mail order tuner!
Might also check with whoever you are going to have fully tune it - some tuners will do a base tune for you under the cost of the tuning or a small charge... I do that if they are close by - especially if they want to change to bigger injectors. Pull out the PCM while the car is down, I flash in a base tune, and they are good to start it up after the install...
